PostNapisane: 2019-04-19 22:42:01
Dołączył(a): 2014-03-01 15:50:26
Witam czy można w Thundercacie regulować wysokość świateł mijania?
PostNapisane: 2019-04-19 23:13:44
Zawsze jest regulacja, u Ciebie powinna byc dwoma srubami na klucz 10mm, nad zarowka jest od regulacji prawa-lewa, pod żarówką jest regulacja góra-dol. Reguluj siedzac na kanapie mozliwie maksymalnie ją obciazajac żeby ustawienie bylo adekwatne do zawieszenia pod Twoim ciezarem. Ponizej oryginalny cytat z anglojezycznego forum thundercata:
http://yzf600r.com/phpBB2/mobiquo/mobiq ... rpage%3D20
"Take a flashlight and look very carefully back up under the gages you'll see the wiring plug that plugs into the headlight bulb.
On the upper right side (about 2" to the right of the bulb plug) there is a 10mm bolt head. That one adjust the headlight side to side.
On the lower left side of the wire plug about 3" away is another 10mm bolt head. That one is the up/down adjuster.
Get a 1/4" drive ratchet a 3" extension and 10mm socket. That setup allows you to adjust in while sitting on the bike.
Find yourself a clear wall are you can aim the headlight at.
Measure from the ground up to the center of the healight.
Subtract 6" from that and put a mark on the wall that far from the ground.
Roll the bike back 17' from the wall with it aimed at your mark on the wall.
Put your ratchet on the bolt. Now that bolt is threaded into the headlight mirror batchet. As you screw it in, it pulls the headlight down. When you screw it out, it pushes the headlight up.
Tweak on it til the top flat spot in the headlight beam is aimed at your mark on the wall.
Make sure you're putting as much of your weight on the seat as possible to compensate for when you're actually riding the bike.
This is not exact, but it's a got starting point. While you ride make a mental note of where it is and if you need to tweak it down or up.
What I did was put the ratchet set in my pocket and went for a night ride and tweaked it a little at a time til I got it where I wanted it."
PostNapisane: 2019-04-20 00:28:15
Tą srubą Góra dół?
IMG_20190420_002707.jpg [108.3 KiB]
Pobrane 929 razy
PostNapisane: 2019-04-20 02:12:25
Pokrec to zobaczysz :) ja nie mam thundercata ale z instrukcji wynika ze tak, ta dolna kreci góra dół.
PostNapisane: 2019-05-08 00:18:53
Zgadza się. Dzięki
